Water Dissolvable Cores
Here’s an interesting article on water dissolvable cores produced through rapid prototyping. Although the article states that it is currently a university project, I am sure I have seen this somewhere before. Can anyone point me to a rapid prototyping company that uses this process?
Many thanks
Many times i have layed up over shaped foam them melted the foam away. Melted out the middle to leave me with a hollow component. Used this for prototyping, things like prototype or one off airboxes, brake ducts ect ect. Never heard of a foam that could be melted away using water however.
Oops, forgot the link!
http://www.netcomposites.com/newspic.asp?6692
aquacore: http://www.nfgsales.com/partners/advanced_ceramics_manufacturing/wash_out_tooling_materials/aquacore
Advanced Ceramics is still selling Aquacore? I thought they moved away from their normal products and switched it completely to a better sealing system. Just don’t forget the seal/coat If you use Aquacore, else you have a layer of sand inside your part!!!
