Very new to composites so please excuse the questions.
Working on molding wakesurf boards on of a mold using vacuum for pressure.
Mold was CNC cut and then we used filling primer and wet sanding to get a nice finish. This mold is just considered our prototype mold so we decided to just make the negative rather than a plug and a fiberglass mold.
Foam was cut on CNC allowing 0.020inch clearance all the way around… Since its foam this number is not perfect but we wanted some clearance for the layup.
Board came out very good, we just have some voiding along the rails of the board. Looking for any advice on how to keep this from happening in the future. We hand brushed in a layer of epoxy as a gel coat and confirmed that the entire rail was well covered. I was thinking on the next one to add some extra epoxy right down the middle of the mold. Then as the pressure pushes in the middle it would push epoxy out to the rails? Again first mold and first time using vacuum with composites so any help is greatly appreciated…
