I have a Thomas 2660 vacuum pump, on free air movement it can suck a bag down quickly. However when i went to infuse a 4 layer 6K cf flat laminate it wouldn’t do it. I was using 500 cps resin. The flow traveled 10 inches then stopped, the resin was still fresh in the cup.
I used perforated release ply under the red flow netting. Did the perf release hinder the flow? It is perforated .030" every 1/4".
Previously, another pump, a little refrigerator vacuum pump had no problems infusing a flat panel, 4 layers cf that was twice the size/area. On that infusion i used peel ply, no perf release.
What is the minimum cfm of pump for infusing? I can pull 27hg all day long with both pumps.
