Is anyone using a double sided tape or other tape to hold down their peel ply or spiral wrap, etc to the mold? I was curious if i need to buy a tape to do that job, or if peel ply will stay put on it’s own? Here is the tape i am kind of speaking of.
I use a double sided sticky tape from the local h/w store. I think it was labelled as carpet tape but is only 1/2" wide and comes on 150’ rolls for about $3. Works well. I make lil’ socks to go over the resin feed and vacuum outlet manifolds with peel ply and that tape.
Bagging tape, duh!
Well, Tet bagging sticky tape is costly to use for everything…
