How can I fix this? Ive tried so many things and am running out of patience.
The parts are either made of 5 layers of 6oz carbon or 1 layer of 11oz and 1 layer of 20oz with 2mm core material in between, depending on the parts purpose.
I am infusing with MVER I believe its called from innerplastics. Or is it interplastics? Anyways, its a VE / Poly blend and I add 1.5 - 2% mekp-925. The 9 gasses off worse.
Infusions go perfectly fine and always with 0 air. After a few min when I clamp off the resin inlet line is when tiny tiny air bubbles start to form in no pattern, everywhere. Then after I demold there is usually air on the surface… I’m losing thousands of dollars no joke.
Any ideas? I’m getting ready to stop clear gel coating the molds and post gel coating all parts, but that doesn’t prevent the parts having air in them, just makes a pretty airless surface…
