Hey guys,
I have a bit of a problem, I need to build a straight tube (8000mm x 30mm) to replace an aluminium tube of the same dimentions.
Here is the problem, it is used inside the exhaust of a turbine and the ambient temp is 1400°C
The aluminium tube was cooled internally with water, and the CF would be too, and since it didn’t melt, I assume it never went over 660°C. The Al tube is too heavy, as it needs to be handled by someone(think of it as a very long broom stick)
I need a prepreg/resin system that can be produced OOAC and still survive.
I have found:
hexcel m65 BMI prepreg that has a 300°C Tg
P2si N18 (tg 360°C)
P2si 900HT can handle 454°C but needs to be autoclaved at 200psi.
Alternatively Starfire Polyramic Resins can do 1000°C+ but needs to be cured in an inert gas at 850°C
Is there anybody that has experience with any of these systems or others that have worked? Ease of processing is important, but in the end, the cost is not a big factor.
Any help would be appreciated.
