Hello, I’ve been experiencing, I wondered if he could create a vertically laminated on a foam core with infusion and have found possible.
I infused two test parts, with triaxial glass skins 900g/m2, one of this with vertical laminate triaxial glass 900g/m2. Vertical laminates are glued are double-sided tape
As expected, the mechanical properties improved significantly in the part with a vertical lamination, specially on compressive strength (for test, I used extruded polystyrene 40kg/m3 a core with a very poor mechanical properties , I guess, that if you use pvc 80kg/m3 wouldn’t have a big improvement)
I would like know your opinions about this technique, because I am improving the properties of the core, but I’m also increasing its weight. Is it worth?
You think this is good idea?
Does this technique has been used before?
Probably this weekend I will do my first part by infusion,(a longboard) this will have two skin approximately of 1200 to 1300 g/m2 of glass, and a core of 80kg/m3 10mm of pvc.
Do you think that it was a good idea apply this technique in this case?
Regards and thank you very much!
And I sorry for my English , I don’t know if all can be understood correctly.
