Autoclave? Sorry, still a newbie. Is that oven curing?
I did wet layup and 150lb weights to press the honeycomb into the FG sheet & resin. Once cured- flip over and repeat.
I need to make sure there is zero flex or print-thru in the panel surface which would come from the air pressure in the cells. That’s why I would need to somehow vent it.
I see perforated honeycomb available, haven’t tried it. I thought it might be weaker since the vertical structure is weakened.
Is the effect of a 1/16" hole into a 1/4" cell enough to have any significant effect on strength? (drilled into the FG sheet, not the honeycomb wall.)
I have a finished product that I need to take to a few different people so they can qualify my work. Bad part is I didn’t consider altitude when I made this. If I made it in San Francisco, but I need to take it to someone on Mt Everest- I’m pretty sure the panel will flex from the air difference with sealed cells. Can’t have any flex in it.
So now I’m stepping backwards to fix this issue. Trying to decide if I should make extra-extra-extra reinforcements so I can vent it, or simply drill small holes into the existing piece.
