So, I’m making a couple sets of velocity stacks out of carbon… going to use sleaving to do it
trying to make something like this
here is my male plug that I made
still needs some surfacing… basically I designed the shape on a 3d modeling program, printed out templates, put a piece of polyurethane foam on the lathe, then vacuum formed over it when finished… chissled out the foam, then poured instacast in… so I have a nice solid plug now… needs a pit of prep work, but then I’m good… now I’m trying to decide the best way to make a female mold… I’m trying to achieve a good finish on both the inside and outside, so I was thinking of making a two part female mold that this fits into. Lay up the sleaves over this plug, then clamp the two female molds onto the outside, and let cure. Will probably leave a ridge along the part line between the two female molds though…
any suggestions?
