Key things to look for in a VE infusion resin are as follows:
High solids content or conversely low VOC content. Some suppliers will list the VOC’s and others will list the solids of the resin. With this in mind a low viscosity resin also is critical for infusion processing. 80-120 cps is ideal. Be careful, you don’t just get a resin that starts out life in a high viscosity, that just has styrene monomer added to it, or you will have a resin system that will shrink at higher rate than normal. I have checked out one of the resins you have listed above, and it looks ok but suppliers data sheets can be vague sometimes, the AOC resin looks ok. Could not find any data on the other.It also recommends that you catalyse with Norox CHM50 (cumyl hydroperoxide), which is to answer your question above, a h2o2 free catalyst. It will also reduce the peak exotherm of the resin markedly with no effect to the cure. Post cure as well, is always a good option to optimise cure, especially in VE’s. One note to be careful of. Not all resins, are promoted at the same rate. Meaning that if you have two different VE’s you would not add the same amount of promotors to each. Consult the supplier for their recommended promotion levels to suit a
Cumyl hydroperoxide catalyst. Also not all VE’s are compatible with CHM50 catalyst, so again be careful.
In house testing is always a good way of determining what suits you, if you can’t get the info from the supplier. A reasonably accurate set of weighing scales is essential for promoting and catalysing of VE’s. In my view your first investment!
Hope this helps, happy to assist further.
