I’ve a lot of 230/380 V 3 phase vacuumpumps for sale and digital and analog vacuum gauges. For more info or pictures send a pm or post a message.
2x Alcatel 2010 3 phase vacuumpumps. They run on 230 / 400V 3 phase, they can run on 230V single phase when you place a condensor, use a variable frequency drive or you can place an other motor. They are in great condition and they come with new oil in it. The price is €SOLD. Can be shipped worldwide.
Leybold Trivac D25B vacuumpump. The pump has been checked, cleaned and there is new oil in it. Pump speed is 25 m3/h and it has a vacuum off 1x10-4 Torr. It runs on 230 / 400V 3 phase, it can run on 230V single phase when you place a condensor, use a variable frequency drive or you can place an other motor. The pump comes with an AF 16-25 mist filter and a molucular 30-60 filter. The pump costs new €5000, the mist filter €800 and the molucular 30-60 filter costs over €1000 new. Together they may go for €SOLD excl. shipping. It can be shipped worldwide.
- Edwards E2M8 vacuumpump.The pump was refurbished in 2007 and never used since (spare). The pump has been checked and there is new oil in it. Pump speed is 6cfm and it has a vacuum off 7.5 X 10 -4 Torr. It runs on 230 / 400V 3 phase, it can run on 230V single phase when you place a condensor, use a variable frequency drive or you can place an other motor. The pump costs new €3000 and this one may go for €500 excl. shipping. It can be shipped worldwide.
- Edwards RV12 vacuumpump. The pump is checked, cleaned and it has new oil in it. Pump speed is 17 m3/h and it has a vacuum off 1.5 X 10 -3 Torr . It runs on 230 / 400V 3 phase, it can run on 230V single phase when you place a condensor, use a variable frequency drive or you can place an other motor. The pump comes with an Edwards mist filter. The pump costs new €3500 and the mist filter €400. Together they may go for €SOLD It can be shipped worldwide.
-Busch RA 0100 F 503 vacuumpump. It has almost no running hours. The pump has been checked, cleaned and there is new oil +filter in it. Pump speed is 100 m3/h and it has a vacuum off 0.1 mbar. It runs on 230 / 400V 3 phase and is 2.2 kw. The pump comes with an used inlet filter. The pumps also comes with 2 new inlet filters, new oil filter and 5 liter off new oil. The pump costs new €4500 excl. filters, ect. The used inlet filter costs €800 new, the other new ones cost €400 each, the oil filter €20 and the oil €60. Normally it costs new over €6000 together and now it may go for €SOLD excl. shipping. It can be shipped worldwide.
- 3x Edwards ADD absolute vacuum gauges. They work on 220V and they measure in mbar, mtorr, torr and some other. The ADD comes with an Edwards 1000mb barocel to measure absolute vacuum. This set normally costs more then €2000 and now it may go for €200 excl. shipping.
- 3x Leybold Thermovac TM21 absolute vacuum gauges. They work on 220V and they measure in Mbar, Torr, PA and Micron. They come with an TR211 vacuum sensor to measure the vacuum. This set normally costs over €2000 new. They may go for €300 excl. shipping.
- A lot of analog vacuum gauges, most of them are from Leybold. They big one is 16 cm and the smaller ones8cm. This are high end analog gauges so no cheap stuff. Prices from €15 up to €60 excl shipping.
