Currently I use West Systems 105/205 and will also be using 207. I am looking at building my own work table/bench. I plan on using it also to cut my fabric and store rolls of fabric under neath the table. I can build the basic table just trying to figure out what to use for the table top. This table top will be a combination of cutting surface, but for the smaller projects, I plan on setting the vacuum bag right on the table (using the table as the backside of the bag), the only issue I have is what to use as a top?
Options I have come up with are:
Formica-laminate: Cheap and easy to install/replace as needed but dont know how well it will hold up or if it would need any extra sealing?
Solid Surface (Corian, etc): pricey, but should hold up to the cutting and the bagging process as it is non porous, thinking I should just need to wax the area for a release.
Butcher Block: can be pricey, according to West System help, I should be able to put 3-4 coats of epoxy on the block, then a couple coats of laquer and be fine, the epoxy I think would add a lot to the cost, but could easily be smoothed out/re-applied as needed.
Stainless Steel: not for sure on the price since Im not sure what gauge I should get, but with a wax placed on it for a mold release, I think it would hold well for cutting and the vacuum process.
Does anyone have thoughts on this? I am just getting started so dont want to have too much money into this table (but could upgrade the top down the line as needed), but I also want a top that should hold up for awhile well (unsure of how well formica laminate will hold up over time)
Thank you in advance for any help.
