A friend of mine is slowly thinking about getting into composite infusion and asked me a question that I wasn’t exactly sure of the correct answer to give him… I am hoping you guys can help me out with this…
He is currently keeping his vacuum pumps on throughout his entire cure cycles, but wants to start using a vacuum pressure switch so they turn off at full Vac and kick the pumps on at pressure loss.
His problems…
Problem 1 is that the torque of the pumps won’t spin the pump back on if the Vac is more than 15hg. So in his set up the vacuum pressure would have to drop significantly before the pumps would kick on again.
Problem 2 is that the switch he is looking at getting would switch back on at a pressure loss of 4hg, so the pumps would be sitting there with power going to them until the pressure dropped enough for the to be able to spin again.
I told him to ebay his pumps and get one that will be able to kick back on regardless of the current pressure and to run the switch that he wants… but I don’t think he is too keen on having to sell his current pumps.
What are your thoughts?
-C
