Hey guys,
After many frustrating attempts and hours lost I need some advice.
I can’t get my vacuum pump to pull ANY vacuum. I am using a rotary vane pump which uses oil. When the pump is connected directly to the vacuum gauge I pull at about 22 with ease.
Once I have the tubing on a mould I can’t pull any vacuum at all. Once I was able to pull some vacuum, but I wasn’t able to measure the amount I pulled.
My questions are:
Does baggin tape go bad? Am i using the wrong type of baggin tape. I mean yellow purchased from Airtec, BUT it is years old, close to 4 years now.
Is my vacuum bag the problem? I didn’t see any holes or any wrinkles at all. I have experience with vacuum bagging but, For some reason I just can’t get things to work
I have tried vacuuming a flat panel on a piece of aluminum and sitll had no luck pulling a vacuum.
Where can I purchase one of those vacuum fittings that the vacuum tubing connnects directly to? I know I can order one. Id like to try and find somewhere local to buy one.
My workshop is in my dads machine shop in Burbank, CA next to the airport. Home is in Tarzana, CA. Help please
It’s not an oven cure tape though to the best of my knowledge.
