I have problems to seal my vacuum probe. I try to stretch bag correctly to have no wrinkles and so on. But I have still leak. I polished upper part of aluminium probe which is in contact with gasket. I have question about gasket. If I look close to the gasket it has a texture, is not ,mirror, finish. This probably helps when locking probe (rotating). I pressed that gasket between clear plastic plates and I can see that texture makes a micro leak paths. I produced my own silicone gasket between two mirror plates. It ,drags, to surfaces and Im not able to lock probe so this is also not a good solution. Can someone tell me if this texture on gasket is standard surface finish and it dont cause leaks? Or Im locking it badly?
Thanks,
Mike
