I will soon be doing my first large part infusion, a 33 feet boat hull, we will use vinylester infusion resin and have a big doubt in regards to the best way to do it, so far, and as far as I know, the best advise has been in order to avoid a too dry part has been to infuse at maximum vacuum levels and when part was infused reduce the vacuum level to 90% (or 27 inches of Hg), this can easily be done in small parts with only one resin inlet, and when vacuum is reduced to 90% the stack decompress a bit absorbing some extra resin into the stack making it a bit more resin rich and better looking.
My doubt arise as how this could be done in the case of a sequential strategy in a boat hull because then at the end of the infusion all the closed resin inlet tubes would have to be reopened for the extra resin to enter the stack and maybe this could cause uneven thicknesses, on the other hand if the hull is infused at a constant vacuum level of 90% since the beginning, the thicknesses are more likely to be equal BUT maybe as not all gasses have been removed ( there are still 10% of them )there is more tendency to getting some bubbles in the laminate, so what should be done to achieve best results? simply infuse at constant 90% vacuum and be done with it ?? or infuse at 98.5% and forget about the laminate being slightly dryer than if done at 90% ???
Please help me solve this “existencial” doubt …
