vacuum inverter
whatever it’s called, when you use an air compressor to make a vacuum. picked one up to start practicing vacbag. i’m sure it won’t product the quality for production that i want, but i figured for 10$ at harbor frieght, it’ll slightly cheapen the learning curve for a second.
vaccuum generator. You’ll actually be pleasantly surprised with the vacuum they can pull.
i did not want to here my compressor runing all the time so i used a shop vac
now that i have had success with small parts i bought a pump from problems so i can start doing some larger parts
If you don’t have leaks, your compressor doesn’t have to run all the time. Build yourself a vacuum/resin pot to keep some backup vacuum too.
