I have done a lot of conversions of hand laminates to infusion.
You are right that thickness can be decreased by 50% due to the pressure of the vacuum bag. This leads to overly flexible panels, which can fail. (as mentioned before)
Lets see what advantages and comparisons can be made:
with infusion:
-resin uptake dramatically decreases.
-void content drops from approx 3% (hand layup) to less than 0,5%
-much less resin rich areas, due to better compaction, leading to a better ILSS.
-ability to use much heavier fabrics, saving on prep time.
-less thickness, due to compaction of the laminate. Resilient materials such as CSM, CFM show a much larger reduction in thickness than less resilient materials, such as wovens, NCF and core materials.
Let’s address the thickness issue:
-decreased thickness leads to more flexibility, even with the same amount of glass.
-tensile strength remains roughly the same.
-in single skin laminates tensile is hardly the limiting factor, where stiffness is.
So the key is to regain stiffness back. As stiffness is dominantly a result of thickness (much more than materials used) it is easiest to make the part thicker. This can be done in 3 ways:
-use more glass. In you laminate scheme I clearly see a system of using some finer layers to maintain surface quality, and a sort of sandwich of Non crimp fabric (NCF) sandwiching a couple of layers of matt. You could opt for more layers of CSM, perhaps some more NCF which will also add to the stiffness, strength and depending on fiber orientation on torsional stiffness.
Another option is to add a core material. A specialised infusion core is Lantor Soric. This core is very easy to use and give good results. Use it in the middle of the stack.
Other options are hard cores, such as PVC foam.
Every option should be calculated in terms of cost, labour and performance.
No time to elaborate now…
