Vacuum Infusion Resin
Will be doing VIP parts for customers soon, just want to know what is the best to use with this method. I know some use epoxy, other VER, and I read somewhere that someone uses gel coat. Need help and suppliers. Thanks
If you need to ask that question on here, are you certain you are ready to get involved with retail trade?
Any resin in the 200cps range is suitable for RI. Even more viscious resin will work depending on the amount of layers your using.
A lot of the time the materials your using dictates what resin you should use. Its a matter of preference also.
Eastern Burlap and Trading Co in Norfolk, Va. 757-622-5914
They’ve got pretty much everything you need at great prices.
http://www.compositeforum.werksberg.com/showthread.php?p=9730#post9730
Here’s where I’m placing composites supplier list and other common items too…
