Hello,
I used to use Airtech Wrightlon 5400 0.002" vacuum foil for infusion only.I was not satisfied with the result. Often I had small holes (probably at folds)that I couldn’t find and the foil was a bid stiff. To try something different I tried the same version only in 0.003" thick. Take the 0.002" version in mind and multiplie that with 10. It doesn’t work with my complex shapes and when it has a fold you see some damage wright away. My first easy product was full with holes.
My supplier recommended me Airtech Big blue but the problem it’s folded and at least 3 m wide . I need a 1,5 m wide foil and not folded. It needs to be asshole prove and easy to work with whith complex shapes. What can you guys recommend me and what do you use for infusion?
If it does , I have a roll of cytec Vacpac hanging on my wall. It’s there equivalent to airtech ’ s big blue , .003" thick. Almost 3 meters wide folded, 22 some feet wide opened. A lot better than the Wrightlon 5??? (It was Clear) I was using.
