tried searching, but couldn’t find any help… here are a few questions i had:
generally, how many lines do you install for a medium-sized piece (about 9"x9")? do you guys usually install one vacuum line per side, or is one line just enough (which is what i regularly do)?
after pulling all the air out, how long do you guys let your pump continue to pull? do you shut off immediately? should i lessen the power of the vacuum a few inches after all the air is pulled, and THEN clamp up the line?
i’ve always had problems with this in the past, but when you setup your bags, do you guys do this beforehand or afterhand? for something like a helmet or fender, is it best to line the bag so that it runs alongside the inner curve of the part w/o too much shrinkage?
thanks guys for the help in advanced.
