I’ve several years using epoxy and hand layup, this is my first real delve into polyester and bagging.
I laid up 2 layers of 7.5oz plain weave, 0° off axis, with fiberglast 77 resin, mixed .0125% MEKP with a spray can primer on the mold surface. Vacuum bagged with release, .125" breather and stretchlon 800 bagging and 99.99% sealed, the only leak was the breach at the air connector an inch outside the part.
Before I bagged it, I made sure it was wetout a bit more than what I would if I was just doing a handlayup part. I figured the breather would absorb the extra, but… it took a little too much. or… I did something else wrong?
The part came out with pin holes in nearly the entire part. The fabric was wetted out, but the space between the fabric was dry, which good news, made for a nice flexible part, but absolutely unacceptable part and would be very difficult to fix the part. i.e. Trashbin.
What I know I didn’t do was lay the 2nd layer up at 45° axis and the spray can primer is obviously a single stage and is not optimal for “production” but for the first few parts may work. I’d like to think the primer isn’t the problem, but I don’t want to go out a buy a 75$ gallon of pain, 10$ gallon of thinner and acetone, and a new needle and tip for the gun, just to get the first few parts out while I learn. I don’t want to have to learn 5 things, when I could just learn 4… and especially when I don’t need more than about 6oz of primer at a time.
Suggestions to start tracing the problem first with the pin holes?
