Ok, if im using peel ply do i still have to use perf release film ? can i put a couple of layers of peel ply down or will one ply work just fine ?
Same with release film can i put a few pieces down ? (the parts im trying to make out of CF is a flat piece with a lip on it 50mm wide x about 200mm long so i just wrap the whole thing in release film etc because its only 50mm wide)
Breather cloth, is there a limit to how much you put down or does it not really matter ? ie is one layer too little if it gets saturated with excess resin ? or will too much breqather cloth make it difficult to drag air bubbles out etc ?
just a few pointers really or tips of do’s and donts would be greatfully recieved
Matt
