Hey Rotorage,
Thanks for the insight. I am making quite a few different molds, some of them slightly convex panels about a foot in diameter, others are brake duct and air ducting in general that are more complex. Soon I will be starting some multiple piece molds after I am situated with these first projects.
I made a pretty cool vacuum station (if you will) where my piece sits on a perforated sheet and the air is drawn down through its many holes and creates one hell of a vacuum. For the piece of I was referring to (relatively flat and simple), I think I could get it under vacuum before it was ineffective.
Im certainly not set on it, I was just curious as the literature I have read on composites/mold making/etc didnt make mention of it either way.
thanks again for your help, I appreciate it!
Also, I have a sheet metal panel that I want to make a mold from and the paint isn’t in great shape. I just soda-blasted it off and I am going to fill in any imperfections and then paint it here at work. Do you think that a high quality primer and paint will suffice in regards to holding up to temperature, etc? Last time I made a mold it was cylindrical and so I put a thermometer in it and it pegged it out at 120 degrees, I didn’t have a laser thermometer on me at the time but I am concerned that I might be exceeding the capabilities of a regular paint. perhaps powder coating is the answer?
EDIT: Is it also a possibility to just polish the bloody hell out of the sheet metal piece to a nice finish and put the gel coat right up against that? It is stamped steel sheet metal. I assume this is okay but I am open to opinions
thanks again!
