Vacuum bag equipment??? Best Companies
Well the time has come for me to upgrade my equipment. What venders/co’s out there carry this stuff?
I mainly want a new vacuum pump that can handle atleast 3 med. sized pieces at one time. If anyone knows of anything like this that won’t set me back $800+ please post it here.
Bill
What size pump do you have now Bill? I am just running a compressor/vacuum generator setup with shut off valve. Once I get to the desired inches of mecury, I just disconnect the hose and check back once in a while for possible leaks. Other than that I don’t really leave the pump running the whole time.
I was using an old AC vacuum but its old and about to die.
anymore info on that attachment piece would be great. I have a 80gal and 30gal compressor in my shop so it should work great.
I got a vacuum generator from Vac Cube (model 180). It pulls a maximum of 30 inches of mercury so that’s plenty enough for me. They have it listed for $180 but I think you should be able to get it from any of their distributor for less than 1/2 of that.
http://www.vac-cube.com or you can just get the one from www.fibreglast.com. I’ve seen several different ones and they’re all in the same price range.
Hello!
I’m interested in getting started with a vacuum bagging setup. I’m a newbie coming to it all, but I have intentions of doing small to moderately large projects.
Projects could include…mainly automotive:
Door Panels
Dash
Engine Components
etc.
Do either of you have suggestions regarding what type of setup I should go with? I’m either looking for a stand alone unit or something that can use in conjunction w/ a air compressor. However, the air compressor wouldn’t be available for me 24/7.
To be able to complete the projects as listed above and like…
Kit?
Prices?
Air Compressor Parts Needed if that route?
Etc Info?
Thanks!
Jason
I started out getting an air compressor and a vacuum generator so I can have both. It worked fine but the compressor was just too damn loud and I don’t want to piss off the neighbors.
So now I’m running a smaller 2 way pumps that vacuums on one end and blow out the other. It runs much quieter and it seems to be strong enough for projects up to 5 sq ft. I don’t see a need to run anything bigger than that right now anyway.
Here’s a basic illustration on all the materials that you’ll need (taken from fibreglast.com). I’ll put up a better pic when I get home since fibreglast tends to get real anal retentive when it comes to using their stuff:
As you can see it adds up. But I can do a couple of write ups to make certain parts/valves/connectors yourself.
More later.
btw, if you decide to go the cheap route (aka compressor+vacuum generator), I have a generator that I’ll let go for cheap. It’s made by VacCube3 and pulls 30 inches of mercury. 27 inches of mercury is the ideal pressure for vacuum bagging. I also have a 2HP compressor also that I can sell. Not sure if it’s worth it after all the shipping though. They’re about $100 at your local hardware store or at Sears. That’s how much I got them for.
If you decide to get a pump, it’s really expensive new so try to see if you can get a used one. I went the used route and ended up doing the electrical wiring myself. I knew nothing about electrical stuff but I managed to get it to work without frying myself in the process.
How much is ‘really expensive’? :slight_smile: I’ve went to fiberglast.com and read up on their literature available and also looked at their kits available. It seemed that the kits started around $300?..Does that sound about right?
Thanks again!
Jason
Yeah you can get a small pump for around $300. If you have a compressor already, you can get the vac generator for about $100. You’ll also need vacuum bag, breather ply, peel ply, release ply, sealant tape, and a vacuum valve.
A perfect setup should also have a shutoff switch so you don’t have to keep your pump running the whole time. A pressure gauge to monitor for leakage, and a collection cup to prevent excess resin to run back to the pump through the line.
Here’s a better pic, still kind of small. I know there’s another one so let me find it.
Ha! I knew there was a better one.
Right on, thank you for the illustrations! When you said 300 for a small pump - what type of psi/cfn am I looking for when I’m thinking about a dash / door panels?
Thanks!
Jason
