So i am planning on doing vacuum infusion of some vehicle body parts in carbon fiber as some one off prototype work to use on my race car and as a means to get a good repeatable resin infusion process worked out for my future structural parts and projects. I have a lot of questions about the whole process as i have never made fiberglass molds off of existing parts or done large scale infusions like a car hood. I will try to ask the questions in a reasonable order from the plug preparation all the way down to the finishing of the components.
I should first clarify i have some experience in wet layup of Fiberglass CSM and carbon fiber, wet layup/ vacuum bagging of carbon fiber. These questions will be a little more specific and most regarding the infusion process. I have read through a good amount of infusion posts on this site and just need some clarification and advice.
So i will start at the plug. I am starting with the smallest component the trunk lid which is roughly 3’x3’(1mx1m). I will be painting and finishing the hood to a very nice finish as if it were going on the car. so i will have a very nice plug. attached to the plug will be a flange which i will attach to the underside of the lid to give an extra 4-6inches around the trunk lid which will serve as a flange for extra materials/ infusion space ect. First point of concern is the release system. in the past I have only ever use wax/pva system because I was never making cosmetic parts. I never really got a nice finish from a part using the pva in a brush on application. If i want the mold to have a really nice polished surface would it be worth the costly investment to go to a frekote system? especially if it is a one off part and i don’t intend to do production with the mold? Will going to a spray application of the PVA net a better finish? if i have to polish the mold no matter what I understand that it would be unnecessary to invest in a frekote system and just finish the surface of mold. that or just worry about all the finishing work on the resulting carbon fiber part.
To the Mold, first i will explain the process and materials i intend to use. i will use the US composites PE 404 tooling resin, 4-5 layers of 1.5 oz/sqft (461g/sqM) fiberglass Matt, PE Tooling gelcoat and potentially a wood back brace which will be glassed into the hood to provide stiffness.
first things first, if i brush on the gelcoat will i still be able to get a nice finish or does it need to be sprayed? do i really need a tooling gelcoat for a mold that will only see 1-2 uses? will one quart (1liter) of gelcoat be enough to cover a trunk lid that is about 3’x3’ (1mx1m)? Is it ok to do the first glass layer with the heavier glass matt or should i buy a thinner matt for the first layer? If I lay down say 3 layers, let it cure then lay down another 3 will that lessen the shrinkage caused by the PE resin? would 6 layers of glass require a wood bracing on the back for stiffness? can you polish gelcoat in the same way you would polish paint on a car?
Onto the infusion process and carbon part. My plan for the part is to use applied polyeramics SC779 infusion resin 300cps and has a 200f Tg, 2-3 layers of 5.7oz/sqyd (200g/sqM) 2x2 twill weave carbon, nylon coated peel ply mesh, infusion mesh, standard nylon bag film(not stretchy), between layer flow media like soric? MTI hose and ive got a big vacuum pump.
first few questions all regard the infusion process and release system. Will a standard brush on pva system work with infusion? will the pva cause a more dull finish on the surface of the part? I read through an entire post about in mold coatings to be sprayed down as like a surface clear coat, is that something worth doing on a part this large? i will be doing a car hood that is even larger. I read that if the part is not infused while the coating is still tacky you will have cosmetic issues. I would like the part to require as minimal finishing as possible but I had already planned on doing a clear coat on the part at the end for UV resistance. Is there a particular resin flow speed across the part i should be looking for or will the MTI hose do the regulating for me? Does the MTI hose need to completly encompass the part or can it be set up like a regular infusion that pulls from one side to the other? for the resin system should i choose the slowest hardener to ensure good wetting of the fabric? I do not have a way to do a higher temp post cure so it will be at room temp 75f. Time really isn’t a factor for me as this is all experimental so if it takes a week to cure thats not a problem. Do I always need to degass the resin before the infusion? when using MTI hose how do you know when to clamp off the feed line? do you have to cut the resin supply before it reaches the last bits of the hose? I understand you can calculate by weight for a close resin measurement but the feed pots and lines get added ect and if no resin escapes you have to cut it off at the right time correct? does spray adhesive effect infusion? I have never used it but see its necessity for an infusion process. how does print through happen when doing infusion? how can it be avoided?
for the construction of the part, do you think 2 layers of carbon would be enough for a fairly stiff hood/trunk lid? it has some contour and shapes that would promote stiffness but maybe 3 layers to be safe? The other point of construction i forgot to mention is I will be using 2in carbon tape around the edge of the part for improved chip resistance and a little stiffness. there wont be any underside ribbing on the part.It a race only vehicle and just needs to be as light as possible but stiff enough that one guy could pick up the part from one side without it collapsing on itself. with only 2 or 3 layers do i need a flow media between them like soric? Is the purpose of the flow media just to ensure that resin gets to the first layer? Is there a limit on how many layers you can infuse at once or is that dependent on other factors like the resin?
for finishing i plan on clear coating the part for UV protection. how do you prep a surface for clear? light sand with 400grit or so and spray clear right to it? how much can you rough up the surface before you hit the carbon fibers? do you have to use a special clear to avoid chipping if the part is a little flexible?
Thank you all in advance for any responses i really appreciate it. Here is the part (in process of being sanded painted ect.) and also the car just for fun. 1962 pontiac tempest. Also if there are any experienced composite guys in the Chicago area I would love to meet up and go over setups ect.
