we stopped using it because we started using epoxy resins that already had UV blockers in them.
in my opinion (and according to tech. data sheets) the epoxy systems that most surfboard manufacturers use is structurally inferior to something you would use on an airplane for example. Its more similar to a clear coat, or bonding epoxy, like west systems for example. However it is generally cheaper than the structurally superior resins, and it is MUCH more optically clear, and bright. Again, at the moment, the surf industry is addicted to making surfboards as bright white as possible.
so again, basically we switched because it was cheaper and made a better looking board, at the expense of some structural strength. In my opinion, i would take a longer lasting board over a prettier board any day. but im an engineer, not the marketing guys…
also, keep in mind that if you are going to do carbon fiber parts, or anything that doesnt have a substrate like foam that you are trying to provide a clear window to underneath your laminate (like a white foam surfboard blank), you dont need a water-clear resin system. also, some surfboard systems have some violet tint in the resin to fool the eye into thinking that its “whiter” over he top of the white foam blank. there is a drawback to this however: when these resins are used for a carbon layup you can see the violet tint of the resin on top of the carbon (or anything else you want to be black / dark)… makes it look weird in my opinion, i dont care for it.
we were getting our tinuvin and other additives from Germany while we were still using MGS resin, also from Germany. ive never had to source it from here (im also in california), but ill take a look around real quick…
-david
