has anyone ever tried vacuum bagging using spiral wrap around the entire perimeter of their mold as a means to draw the air out of the bag and to ensure that you have a full deep vacuum drawn over their entire mold?
I have a very large mold, It’s 10 feet long, about 18 inches wide at it’s widest point and 22 inches deep at its deepest point, sort of canoe shaped but for a streamlined human powered vehicle.
I usually work by myself so when It’s time to do a layup I am going fast and furious to get the fabrics saturated and to get the bag around the huge mold.
I have pulled a couple of parts out of it using vacuum valves at fore and aft but I have found out after pulling the parts out that big pockets of resin have been trapped in the middle perhaps from having the resin cutting off the flow of air and it seems that no matter how much breather I put in there I get things like this. I can’t put my valves in the mold itself, they print through and leave distortion on my part, I have to put them on the flange at the nose and tail. I use tons of breather around the inlets and run long pieces down the center of the mold to ensure that the air is not cut off in between.
I’ve thought about going to a fully infused part but I don’t like how I have to change to a very thin epoxy resin. I like using Adtech el-335 but it’s just too thick to infuse. It wets out fine in a standard vacuum bagged layup but it doesn’t like to stay on the almost vertical walls of my mold so I get lots of pinholes around the more vertical surfaces in addition to the pockets of resin in the bottom of it and in the middle.
logic is suggesting to me that having spiral wrap around the entire perimeter will help draw a more even and consistent vacuum over the entire mold. Has anyone tried this?
My pump can pull 29.5 inches so I know I can get the pressure to flatten out these spots, I have even built a 6 port vacuum supply manifold with valves and vacuum gauges so that I could potentially use them to monitor the actual pressure at various spots around the mold.
I have a 75 gallon air tank that acts as a ballast so that I can evacuate the huge 12 foot long bag I need to surround the entire mold quickly after I saturate the fabrics and I use huge .500 ID vacuum lines and It only takes 3 minutes from the moment I seal the bag to the time that it is tight around the mold.
I weigh all the fabrics going into the mold and then add 30% more resin, 8-10% of that winds up in the mixing cups. I have gotten a 55/45 ratio of fabric to resin by weight. The rest of the resin winds up in the breather and peel ply. but I get tons of pinholes along the sides and pockets of resin in the middle.
Maybe some of the resin is kicking early when it pools in the middle and then blocks off the breather but that is just a guess. I usually get a 45-60 minute work time with this resin and the bag is at 20 inches or better an hour after the first batches were mixed.
Am I doing something wrong here?
Any suggestions?
port and spiral wrap around the edges. It sounds like you are having trouble with the even transfer of your vacuum onto your parts not in direct contact with the bleed and from your description it sounds like you don’t cover the whole part with bleeder, if you did so it should help with [vac](javascript:void(0)
