Ah that was the regular FSAE car. I was on the Hybrid team, we went to New Hampshire. Our composites work was not even close to top notch, something I hated, simply because we had to spend all our money on the parts that actually moved the car. I did help the the better funded FSAE team frequently though, they were in the lab next door.
[ame=“http://www.youtube.com/watch?v=Kgman94y1EM”]Formula Hybrid 2011: Cal Poly Pomona Tilt - YouTube[/ame]
To reduce your cost with composites start calling companies immediately. For sure you’re going to need tacky tape and bagging material so get some of that as fast as you can. After that depending whether you decide to go prepreg or wet layup you’ll have a whole another list of supplies you need.
As far as stiffness goes an easy way to check is take your frame model and add plate element over all the gaps in the spaceframe in which you’re going to add composites. Depending on the layup you do, change the material definition to reflect anisotropy. I suspect you’ll use two layers bidirectional, as it’s the lightest layup that wont have pinholes in it. For the floor if you add enough layers you can actually stand on it, instead of having to have your driver step on tubes. Another added benefit is the driver compartment is usually is the least stiff since you have to reduce the number of tubes. Adding extra material to this area could help with that.
For the FEA just run it bare frame, then run it with the covered frame through all the regular torsion, cantilever etc loadings. This should give you material to give to the judges. For density, typically aluminum is 2.4 g/cm^3 on the light side. All the composites I’ve seen made in student shops like yours have been 1.2-1.7 g/cm^3. Thickness of my plates have been between 1mm to 1.3mm for one of the fabric styles I used.
Combined with area you’re going to cover over your frame this should give you enough data to get some preliminary calcs done, both for yourself and the design portion. Competition is stiff in your division. Let me know if you need any other help.
