I am so glad I found this forum. Hope you guys can help me.
I have two canoes.
One homebuilt woodstrip (epoxy/F/G with 6 coats of UV varnish) and an ABS royalex. They are both my “Babies” and I’d hate to ruin either one. I’m thinking of using one as a male mold to lay up another hull. No vacumn bagging, just fabric, epoxy and sqeegees.
Am I way off base here? :shock:
Will the epoxy cause any damage to either the royalex or woodstrip?
What about the heat from curing?
What sort of release wax/agent should I use? And how should I apply it?
Will I be able to get the new hull off without ruining my existing canoes?
How do I get the release agent and wax off the canoes when I’m done?
The technique I have in mind calls for leaving the bow and stern open until removal so the sides can be flexed, then closing them up seperately.
I have tried posting this question on canoe and kayak builders forums without much success. Most said “DON"T DO IT”. But then they never had done it.
One fellow did say he used heat shrink window plastic to cover his woodstrip canoe and laid up a new kevlar hull over that. When it was cured it supposedly popped right off and the plastic left a reasonably smooth inside finish.
As far as the fabric I haven’t made my mind up as yet. Carbon fiber or one of the new carbon/kevlar hybrids would be nice. I am thinking one layer of CF and then one layer of 4-6oz S glass on the exterior, with some kevlar in the ends and bilge for reinforcement, then a few transverse ribs to firm up the bottom and prevent oilcanning.
Thanks for your ideas!
