Use topcoat on vacuum bagging
Hello, currently I finish fabric parts using a topcoast, but the problem is that I apply with a brush and it doesn’t give a good finish.
To improve the finish (and other things), I was thinking build a vacuum press to apply the topcoat on the finished parts, then, I would place the piece whit topcoat fresh in the vacuum press, so when the vacuum is applied, resin will spread evenly giving smooth finish. Is it a good idea?
But the question is, if I can use for this or other vacuum applications a topcoat resin, because the topcoast is used for air curing, but, only for air curing?
A greeting and thank you very much
Why don’t you put a top coat in your mold before molding? Give a great finish and no coating needed after molding.
Search in mold coatings, wyowindworks gave a very nice write up.
Hi Ro Yale,the problem is to give finish to peelply side.
Ok I will look
Regards and thanks
Click here for Wyo’s very nice writeup about IMCs.
Yes, that is the thread I’ve been looking, but it does not talk specifically about topcoast, The topcoast, is a gelcoat with some paraffin, not? To have a complete cure in the air, I’m wondering if then, when it’s in a vacuum bagging, the paraffin of topcoat can be a problem.
That is to say, I could use the topcoat like a normal gelcoat.
Greetings
I would use a gel-coat that doesn’t contain wax.
