Some advice please!
I am currently working on a project that needs a large female tool.
The tool will be 20m x 6m and is for a race yacht prepreg hull in Gurit SE70
Target temp 80-85 Celsius. Minimum 3x cure cycles.
Female tool laminate thickness will be 9mm for all options.
The options on the table are:
- To build a CNC male plug and make a carbon/epoxy wet lay & Vacuum female tool.
- Build a direct to female mould in carbon/epoxy, epoxy tooling paste & CNC’d.
- Build a direct to female mould in carbon /Vinylester, epoxy tooling paste & CNC’d.
My preferred option is either 1 or 2… I have used these methods before.
The CNC facility would like option 3.
I did some homework and the VE resin that the supplier will use has 8% shrinkage on the data sheet… Which makes me very nervous!
My priority is Dimensional accuracy as this is not your typical yacht.
Can anyone with direct experience of large VE & Carbon female tools give me some pros and cons?
Is 8% in the normal range for VE resins.
The resin in question here is “Distitron” VE 100 ST
Thanks.
