…is this pump any good for bagging and / or infusion ?http://cgi.ebay.co.uk/VACUUM-PUMP-ROBINAIR-28-l-m-EXCELLENT_W0QQitemZ7586406333QQcategoryZ53226QQssPageNameZWD4VQQrdZ1QQcmdZViewItem
Many thanks
Graham
Many thanks
Graham
it is a good pump but it is only 1.2 cfm so it will bag down very very slow
do you know if it a rotarty pump?
It does look like it has an oil fill bung at the top of the vacuum side, which is very good to know as then it is not a dry vane type, but like DT stated looks on the small size. Fine for smaller projects but…untill you get it and try it with different size molds…?
Hmmm…this one any better ? http://cgi.ebay.co.uk/ITE-Vacuum-Pump-MK-115DV-Airconditioning-Refrigeration_W0QQitemZ7588110304QQcategoryZ42912QQrdZ1QQcmdZViewItem
…or maybe better yet - just seen this http://cgi.ebay.co.uk/Vacuum-Pump-Air-Conditioning-Twin-Manifold_W0QQitemZ6034622387QQcategoryZ20699QQrdZ1QQcmdZViewItem
Does that one look ok? 2 cfm is good right?
Many thanks
Graham
