Ok I figure I’d ask since someone has probably had this issue…
Sometimes, in certain areas my tooling gel doesn’t cure. It’s typically around where I do clay work. Meaning if I bridge the edge of the part to the flange it’s that area. It may be only 1/4 wide or even smaller or larger. The gel coat I don’t think is any thicker or thinner in that area.
I use frekote nc770 and then dolphin wax. I’ve had this issue before but just deal with it and fix my mold later on after I pull the first part.
I’m thinking its moisture but is there any way to fix this or is my best bet to just dremel it out then pop some new tooling gel in there vs risk pulling a part and potentially pulling up more than just that section.
