So let’s say I have this wonderful 20pound roll of AS-4 unidirectional pre-preg tape.
Anyone want to play with some?
Disclaimer: It’s polyetherimide.
I’d give it a try. Need to make some strong tubes. Is it epoxy compatible?
i’d like to try some. are there instructions with it?
Does it require a heated press to mold?
KnottyBuoyz, no it isn’t. It’s a thermoplastic pre-preg. It’s like a stiff plastic sheet. (well, obviously only in the fiber direction)
Everyone else. Yes, i would include some plastic instructions, and yes it needs heat of some sort.
Around 600-650f. (315c+) Sorry, no kitchen oven this time
PEI:
High toughness with good chemical resistance. Low flammability, smoke and toxicity. Standard grade not recommended for use in hot hydraulic fluids. Improved environmental resistance grade available. Applications include aircraft interiors and high performance industrial applications.
Process temp (F/c): 600/315
Service temp (f/c): 300/150
Toughness: High
