Ultra Clear Gel Coat
Now that the web store is closed, where can I find the same Ultra Clear Gel Coat with UV protection?
You could try Fibreglast’s clear gelcoat.
try www.Revchem.com Plastic and tell them “JM” from the GGROP sent you. They have bent over backwards to help our underfunded Plastics job training program.
JM
:shock:
FYI Revchem sells Ultra Clear Gelcoat called Duracote or Durakote but it’s polyester based (it took me since GGROP’s post for me to figure this out!!! They kept forwarding me to irrelevant places).
I need non-poly based gelcoat since this is going onto epoxy. I know the poly may work but it may not adhere properly and it will certainly crack over time outdoors.
Ferro also has UltraClear Gelcoat (this one is actually the trademarked UltraClear) but it too is poly based. They sell this in 5 gallon pails. Anyway, from what I could tell, this is a good one if you are interested in poly.
I’m considering other stuff that isn’t gelcoat and I’ll post my findings… eventually. If you know of anything that can provide UV resistance, is clear, resistists chemicals etc, and is compatible with epoxy, please post.
