Easy Composites’ Uni-Mould “system” of gelcoat, coupling coat and laminating resin looks like a very simple, easy-to-use product line. I’ve read that it’s actually manufactured by some other company and just rebranded, which makes sense. Does anyone know if the same products are available here in the U.S. under a different name so I can save on shipping? If not, maybe you know of very similar products that work in the same manner, i.e; Brushable VE gelcoat, PE laminating resin + CSM, minimal shrinkage, etc. I’m also open to suggestions for alternate methods. The part will be non-structural CF with an emphasis on cosmetics, about 12x30 inches, 3 inches deep so not very large.
In for answers about a vinyl Ester gel coat state side. They make iso poly resin that’s low shrinking or so I’ told anyways.
