What all do you guys use in the lay up of a carbon fiber hood. Very few on the market use a core material. I’m just curious because the hood I want to make I want light as well as good looking. I plan on using a fiberglass replica of the frame underneath, but I was thinking a layer of carbon then a layer of core material, backed by a layer of woven e-glass.
Is that typically how it’s done? Or just lots and lots of CSM?
Also, are steel mounting points necessary? Or can wood with threaded inserts be used for weight savings?
