Type of Ply Failure
Hi Guys,
I’m actually calculating a simulation for one of our products. I would need your experience.
If you have a ply made of a standard fiberglass woven [0,90] textile with a phenolic matrix, ply thickness would be 0,5mm (0.01968498 inches).
Under a flexion load (see Illustration), do we have:
  • a complete failure, matrix and fibers’ cracks?
  • a partial failure, only matrix’cracks?
  • a partial matrix and fibers’failure (let’s say only 50% of the fibers in the direction crack)
Thank you in advance for your help.
Generally, the matrix would crack and the fibers on the upper half of the laminate would buckle. It is likely that no damage would be visible from the back side.
A single ply failure, I would imagine with pheno matrix, you would get 50% failure of fibers, and i would imagine all matrix failure in the damage zone.
I’m guessing that you can’t test yourself? I don’t know much about, or have any phenolic resin.
I will test it but thank for your help, performing a ply by ply failure simulation without the appropriate praxis background is not easy.
