Hi everyone,
If I add fumed silica to this high temp resin, to make a gelcoat, would that be ok to use as the surface layer of my moulds:
http://easycomposites.co.uk/products/epoxy-resin/very-high-temperature-epoxy-laminating-resin.aspx
Or would it be better to use the following tooling gelcoat with a pigment added:
http://easycomposites.co.uk/products/epoxy-gel-coat/clear-epoxy-gel-coat.aspx
