Hi, I’m new to this, I am learning a lot in the forum, but still I have many doubts, now I am facing to problem of how to control the vacuum, to counteract the bag leaks.
A precise vacuum controller may be too expensive, plus, I only need keep the vacuum as low as possible, below 28.5-29Hg.
However, make an electronic timer is very easy for me, then, I had thought to make a controller that turn on and turn off the pump for some concretes periods of time.
Example: 30 minutes off, and 1 minute on.
The question is: Is it bad for the pump, turn on and off repeatedly?. Example, if I turn on 15 seconds every 5 minutes for 12 hours. Could damage the pump?.
I need to know this to know how to set the timer.
Sorry for my English, you maybe not understand me too well.
A greeting and thank you very much
