Looking for possibility to produce tube length 35 mm ,OD 2.7 mm ,ID 2.5 mm .
Ability to handle axial load up to 100 N without bending
Tapered end length is about 3 mm (could be adjusted) .Front hole is 2 mm diameter
2 funneled side holes 4 mm away from tapered end
