Hi,
I’ve been making some tubes and the stiffness is not matching theoretical calculations so I wanted to ask the forum what should be expected as a normal variation from theory.
The tubes are prepreg roll wrapped on mandrels, shrink wrapped and then cured as per the manufacturers cure schedule. The calculations are done using composite pro and using my own spreadsheets, with input from the datasheet. Composite pro and my calculations match.
I’m measuring the tube stiffness by fixing one end and applying force at the other and then calculating the stiffness from the deflection.
I’m fairly confident in the theory, and I’m fairly confident in the measurements, but the results are about 20% lower than theory.
What I’m wondering is
1: Is this a normal variation for this method or should the results be better?
2: What results are achievable for other methods for example filament winding?
3: If I need a tube of stiffness X from theory, should I over build it to take into account the variation?
4: How realistic are datasheet figures likely to be in real world situations
Any thoughts would be very welcome.
Thank you
