Is it possible to use pre-preg in molds that were created for infusion? None of my molds were post cured, and none were created with high temp resins. I use epoxy for 99% of molds. I am more or less trying to see if I would actually have to go back and re-create all of my molds, and post cure them, if I wanted to make the change to pre-preg.
I think Gurit sells a low temp OOA pre-preg, but I think even that product requires a 150degree F cure cycle. I know I could go back and find the heat deflection temps for the epoxy resin and epoxy putties that I use in mold design, but I am sure that 150 degrees would be pushing the limits…
Has anyone ever used normal room temp epoxy molds in a (relatively) low temp pre-preg cure cycle?
