Here is what I am trying to do:
I know it seems easy but i have been struggling with cutting the 2" dia holes perfectly.
Here’s what Im thinking now. Use some 1/2 inch thick aluminum plate cut to the final size.
Drill-bore the 2" dia holes in the plate.
Do a wet lay up of my carbon fiber over the aluminum plate. Use a dremel tool with the sanding wheel and trace the bore. This way my aluminum plate acts as a template.
What do you think?
How would you make this part?
What is an easier way to make this part?
I have access to a manual machine shop and lots of saws, routers and more
IDEALLY: I would like to just use some balsa wood or some 1/8th thick aluminum plate with the holes bored into it and just do a wet lay up onto the final core piece, and do the same router technique ont he final piece. This would avoid gluing things twice.
