triming the edges..
Hi guys,
how would you trim and finish the edges while working with a core (lantor soric in my case) as seen in the picture. it is a flat piece and will be cut using waterjet. However I do not want the core to be seen in white. using black pigment is not an option since it is a cosmetic part. can I add pigment to bondo and lay thin layer over the edges and paint?
any suggestion would help
thank you
Bryan
Route out a couple of mm from the edge and fill with black epoxy and polish it up. Some people use a black wax crayon but not sure how durable that would be.
