Same for large projects, but there is not always the opportunity to apply tape to a bag alongside the project. (projects larger than a table). Whenever I have the opportunity, I order the people to put protective cardboard on the floor, layout the vacuum film, and put tape around the perimeter. But sometimes you just have to do it in situ.
Nice other tricks:
as long as the epoxy is still that soft that you can press a thumbnail into it, you can laminate it over without sanding. (no amine blush should be present).
If you have 2 vacuum pumps at your project, connect them with a hose before the infusion starts. (keep the valve closed). If a pump fails, you can save the project by just opening a valve, instead of hastily running around with hose and bad fitting end fittings.
