Hi,
Have a look at the photograph.
It is a Carbon-Epoxy cylinder of 370.0 mm Diameter.
It is mfged by Closed die and Va-RTM process. The resin is injected form bottom to top.
Problem: We observed such pattern (Refer pics) on the some of the surface of the part. especially on the top side .
They are very small in size and are large in number.
FYI: I do 2 hours of degassing before impregnation also. It has successfully passed UT also. So i believe it is on the surface only
Can some one say why this is happening in spite of vacuum & degassing?
