I realize the Rocket Shells CF drums are epoxy finished. The deal is I am not wanting to paint the exterior to get the color I want. The company that is going to make a drum kit for me makes solid fiberglass shells without any core or carbon fiber in the construction. The fiberglass drums in my opinion sound better. The trick is to achieve this shade I have seen here from Rocket that I like or something somewhat similar that the other fiberglass maufacturer (Tempus Drums) can and will do, utilizing more of his methods, not Rocket’s. Because he did not offer a finish like this it is basically up to me to do the research in what materials might work to get what I am after and pass it along to him to use.
Tempus drums, who I am going to have make my kit, does in fact use gel coat as their exterior finish which is sprayed into the mold prior to the layup. He shoots a clear gel coat into the mold first followed by another gel coat layer that is tinted an opaque color or utilizing clear gel coat with glitter added and then follows that up with a mat and cloth layup using polyester resin. The shells are relatively thin and the finish on the outside is really nice, smooth and shiny which is the side that parts from the mold. So inotherwords, it is a female mold creating the smooth outer exterior finish of the drum and the interior of the drum has a raw fiberglass finish texture from a hand layup. I own a single shell made by Tempus but now am interested in a whole kit. Tempus typically makes opaques and glitter finishes which are very nice but I was looking for a metallic look, not a sparkle, hence my thoughts of having a silver background of some kind overlayed with a translucent blue. Simply using dyes added to gel coat will not do the trick or achieve this look.
Also the cloth I was talking about using for the outer layer that would be seen is not carbon fibre. It is nothing more than an aluminized fiberglass cloth (actually nickel I believe from a description I read). It is a silver colored weave which looks very cool. I realize the “blue leaf” Rocket drums do not have a weave in its finish, but I thought perhaps the aluminum colored weave may look good behind a translucent blue in a layed up part and thought it was worth a shot. I know it will take some experimenting I’m sure if I am hung up on achieving a shade such as this.
