Hi folks,
Just started waxing a plug this weekend using some new TR-108 release wax that I picked up a while ago. When I opened the tin I was wondering if it had been sitting for too long… there was a hard surface on top, not sure if that is normal? The only other wax I’ve used before was a blue colour with solvent mixed in so it stayed liquid in the tin.
Anyway, I had 5 coats of the TR-108 on the plug and thought I’d try the “tape test”. Took some masking tape and pressed a small length onto the plug and it stuck… now I’m wondering about this release wax.
I followed the application directions, wiped on, then off before the wax dries (it does go on with a slightly “wet” appearance, and if left it would take on a bit of a haze). Leaving 30 minutes minimum between coats.
I’m just wondering if I should be worried about it, does the tape test always work - or are there some waxes that the test doesn’t work with?
I put a few drops of water on the plug and it beads up and just rolls right off, so it looks like the wax is on there. Just wondering about this because I haven’t made many parts and have never had a 100% successful release with wax - but previously I’ve made errors in leaving too much wax on the surface which I now know is actually bad for a good clean release. This plug with the TR-108 has no visible signs of the wax, no steaks, haze etc. just the painted surface of the part.
This plug I’m starting with is a really simple one, so I will probably just end up going ahead and give it a try anyway.
But if anyone has experience specifically with TR-108 I’d be interested to hear about it.
Cheers
Edit >>
Just trying to look up some info on Google and already finding conflicting instructions about how to apply TR-108. For instance:
Although I have a new plug (not a new mould) that makes me think I should just wash down my plug and start over…
Or should I really be using the TR-301 sealer before even applying any wax?
